Never settle for lesser 02 sensors. GET AC DELCO. you can get them at a good price at http://www.gmpartsdirect.com Sure they are expensive. but think about it. If your gas milage is bad then that will cost A LOT more then replacing your 02's every few years
When to change oxygen sensors?
1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Bosch doesn't make the O2 sensors GM puts out?
I know NGK makes the AC Delco Iridium plugs I installed in my car.
Originally posted by joecool:
I found this cool wholesale place. They're cheap there. Bosch GM type o2 sensor. http://www.autobarn.net/bosoxsen.html
Is 2 for 31.90 a good price?-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
You on;y need 2 02 sensors. The 2 fronts is it. Rears have no effect on the cars performance. Like I said. spend a little over 100 on 02's every few years or even more on gas cause it's getting eaten up from poor performance. a CA test done on 02's stated that 75% of all the cars tested had 02's that were efecting fuel milage.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by HBHRacing:
You on;y need 2 02 sensors. The 2 fronts is it. Rears have no effect on the cars performance. Like I said. spend a little over 100 on 02's every few years or even more on gas cause it's getting eaten up from poor performance. a CA test done on 02's stated that 75% of all the cars tested had 02's that were efecting fuel milage.www.turbov6camaro.com
1997 3800 Series II Camaro
35-40 MPG.www.turbov6camaro.com
how much do you guys get with the 3.4s? mine is eating so much gas, i think a v8 is more economic. my 02 sensors are definetely burnt up (184k miles)... i have a high flow cat, so i cant put the sensor on that. what do i need to change to get decent gas mileage on my car? with todays gas prices, you cant afford not to spend $300 on sensors, you'll get that money back in a month or two. btw.. i think my car is getting like 15mpg, at most. i failed emissions, (they sniffed a corolla, so i passed [img]smile.gif[/img] ). my engine was rebuilt 3k miles ago, so compression shouldn't be a problem.
I get around 30 mpg now that I recently changed my spark plugs, fuel filter, and filled up my tires. Would the new o2 sensors give me even better mileage??? I would really like to see 35-40 MPG.
My old 3.4 got worse gas mileage than my 3800 does, like 17-18mpg city on a GOOD day... I think its the nature of the beast, change the O2 sensors and go from there.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Originally posted by c a m a r o:
how much do you guys get with the 3.4s? mine is eating so much gas, i think a v8 is more economic. my 02 sensors are definetely burnt up (184k miles)... i have a high flow cat, so i cant put the sensor on that. what do i need to change to get decent gas mileage on my car? with todays gas prices, you cant afford not to spend $300 on sensors, you'll get that money back in a month or two. btw.. i think my car is getting like 15mpg, at most. i failed emissions, (they sniffed a corolla, so i passed [img]smile.gif[/img] ). my engine was rebuilt 3k miles ago, so compression shouldn't be a problem.All black 94 3.4L Camaro <br />5 speed with t-tops<br />Mods-<br />Cold air intake, Duels no cat<br />Iroc rims, Manual fan switch
