My fuel gauge is crazy and out of control. I was wondering if its just a fuse or something simple that can be fixed. I dont like to see my tank 3/4 full when i drive 30 miles.
Fuel Gauge Fuse?
define "crazy"1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by HBHRacing:
define "crazy"Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
there is no fuse for teh gage. There is one that suplys power to the cluster but that has no effect other then it would simply stop working. The sending unit in the tank has a resistnce bored that will send a ground signal which gives you your fuel level reading. Most issues are a fault in the sending unit. This can be somewhat tested. if you would like to know how lemme know. but still. define "crazy"1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Ok
Crazy: 1.after filling up, 30 miles puts it to 3/4 tank
2. turning can move the needle on the gauge from full to 1/2 or less.
3. when its at 1/2 full, the exact amount of gas in the tank is around 1-2 gallons.
4. even when theres 1-2 gallons in it, no gas light or anything goes on.
My car does it. Ive worked it out though:
When im full, the gauge is about 1/2" past 'F'
When i have a half a tank, the gauge is on the 'F' line
When i have 1/4 tank, im at the 1/2 Full line
when my car has vapors left, the gauge is resting right above the line.
When the gauge is even with the line, my car dies.
Originally posted by Wicked 3800 V6:
V-shaped tank. Get used to it. [img]smile.gif[/img]
Then one hot sunny day about 6 months ago I drove up to a ski resort and back down. That morning the gauge was working fine, that evening everything went to ****.
I've noticed that if the car is cool or left running that the gauge will go back to normal, but while driving or if it's been left out in the sun it's reading about 1/4 tank too high.<a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
