i just recently changed my battery and got a new alternator. took it off and had it rechecked soi that i know that the alt. is not at fault. my problem is that everytime i hit the brakes the voltage drops right above yellow and goes back up. now it doesnt do it when i am applying the brake rather when the car finally stops. what the hell can it be. i understand it dropping to 13 volts but not below. What the heck can it be, i have nothing connected to the electrical system besides my air/fuel gauge.
voltage dropping when coming to a stop...
Annoying eh? Mine has been doing that since new. So, it's pretty much "normal". You must have a stick shift. If I pop it into N while cruising at nite, the lights will dim too.
[img]graemlins/burnout.gif[/img]1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
Yep my 2000 did that - but oddly my 2002 M5 doesn't... Maybe they changed something or it has to do with the transmission, but its normal.2002 5-spd NBM Camaro
Details: www.1lev6.com
it doesnt happen on mine either it must be have been fixed for 2000•)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
yeah they proably fixed it for 2k+ but if you ask about say.. a 98.. they will say it's normal and supposed to do that.. oah and yes mine does it too..-Brad
2000 V-Star Custom 1100
:rock:
Mine was doing it too, except all my light would dim. I replaced the alternator and everything was fine again.
I would check the larger red wire that runs to the alternator, make sure it is in good condition. Check the ground cable, make sure it is getting good contact.
Have you replaced the belt latley? Just out of curiosity, does temprature seem to have any effect on it?<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
I have a 1993 camaro with 85,000 miles on it and the lights don't dim when I put the brakes on hard. I don't no wwhat wrong. hard to say-FLOWMASTER 80 series exhaust dual out,K&N air filter.<br />-Bright Rally Red, 1993 Camaro V6 automatic. No BIG mods yet! But who needs alot of mods when you have 160 hp? Kumho ECSTA Supra 712 tires 245/50-16\'s \"Great tires\" <br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG</a><br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG</a>
A similar thing was happening to my car also. I found that condensation was building up in my tailights and semi-shorting out. Everything would dim when I touched the pedal.1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
I have it to, the rev's will drop, oil pressure, voltage, dimming lights....I have checked and rechecked the battery cables all over, everything was good, and making good connections. tested my alternator, it's good too. So I dunno.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
I had the same problem....I changed the alternator, the problem went away for about 4 days, and then started again. A friend of mine said that he had the same problem on his truck (Chevy), and somebody else told me that GM cars and trucks have been having that problem for years.
Basically, it seems like something is eating the regulator up. Either the regulator is junk, or there is something that is causing it to go bad. I'm going to check out my wiring harness when I get a chance (it may be a while), but I'll let anybody know what I find out. LimitedE may be on to something, so I'll start there.
Basically, look for bad grounds (not reading zero ohms), or any other connections that either shouldn't show any resistance and do, or that are supposed to have resistance, but have too little or too much (i.e., supposed to be 5 ohms, but is reading 7 or 3 ohms).Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
