anyone ever used the JB Weld quick setup stuff? I had to put it on my TB and wanted to know how long it will take before it is fully dried and hard......it says it only takes 4 minutes to setup on the package but its taking longer
JB Weld question
JB wled is the ****. i love that stuff. it does usually only take a couple minutes but it all depends on humdity and temp. why are you putting it on your TB?
If it says 4 minutes to set, give it 1/2 hour to be totally sure. Why take a risk over a few minutes.
I don't trust the quick dry JB Weld. I buy the regular JB Weld that takes about 8 hours to cure. I ~believe~ it holds better. Just my opinion though.sigpic
it sets up fairly fast but I never liked it. I would use a better epoxy personaly. It still reqires a good amount of time to really cure.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
