hmm..
when i take my car's RPM's up under load to about 2500 and above, my voltage meter goes down into the yellow. from 14 volts to whatever the middle of the yellow is. the higher the RPM, the lower the voltage goes. so 2500 would be at like the beginning of yellow, and 5k would be neard the middle of yellow, maybe lower. when in neutral, or park. its like 3500 for it to start dropping. i'm not quite sure what the problem is, but i think i isolated it to the belt possibly slipping.
i just took the car in not to long ago for overheating(was the thermostat). but they took my belt off to manually turn my water pump to make sure that it was working. i'm thinking that they might of not tightened up the alternator pully all the way, or whatever you need to tighten. i had my mom rev the car up and i watched the belt spin around, but i'm not totally sure what slipping would look like.
if it is slipping, how would i tighten that up? i don't really feel like going to my shop about this if it is just slipping. but they would tighten it for free for me anyway.
does anyone else have any other opinions. has this happened to anyone else?
also, how much voltage would the battery put out? isn't it odd that the voltage would drop so low?
well any opinions/help is welcomed. thanks.
