Has anyone with a 3.8L done this? If so can you please post pictures...I know how to do it just need to know what hoses you had to connect together or how you did it.....also a list of supplies would be good cause I know it is different from the LS1 and LT1's
TB Bypass question....please help
Originally posted by 98_birdman:
Has anyone with a 3.8L done this? If so can you please post pictures...I know how to do it just need to know what hoses you had to connect together or how you did it.....also a list of supplies would be good cause I know it is different from the LS1 and LT1's94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
Has anyone with a 3.8L done this? If so can you please post pictures...I know how to do it just need to know what hoses you had to connect together or how you did it.....also a list of supplies would be good cause I know it is different from the LS1 and LT1'swww.turbov6camaro.com
1997 3800 Series II Camaro
coolant plug? what is that???
would it be possible if i could find something solid that i could cut out a section of the hose and buy 2 more clamps and clamp it there so no more fluid flows past that?www.turbov6camaro.com
the plug from ZZP wil not fit the Fbody passage. you need to physicly block the passage1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
dude, the hose goes from the radiator to some metal pipe on the drivers side of the TBwww.turbov6camaro.com
For the money, buy the TB spacer from zzp (about $45). It blocks off the coolant flow and comes with everything you need.<a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
