Says "Evaporator Emmision Control System Purge Valve Fault"
Anyone ever have this code before. I replaced the purge valve about three years ago, but do you think I need a new one already? Any other ideas??
-Marc
[ October 13, 2003: Message edited by: hockeyman ]</p>
Ok, well I found the problem here. To start with, the code was 0441, not 1441 saying "improper emmision system purge flow fault". There was a light hissing sound from under the hood somewhere, and I could not find it, until...
I bought another purge valve from autozone, and when I went to install it, I found that the plastic hose coming from the intake (where the seafoam pours into on 3.8's) had a nasty crack in it where it came in close contact with the alternator. The leak was making the evap emmisions system go squirrley, and throw the 0441 code.
