Ok so when my a/c is on and I hit overdrive going about 60 my car misses like a mother :mad: but not with the a/c off.I know cars run doggy with the a/c on but this vibrates the whole frickin' car. I put plugs and plug wires on last week and ran a thing of stp injector cleaner through it but no change. I don't know if the injector cleaner really works or not because I think it's a fuel problem because when I pulled my plugs they were white which I think means it's running lean. So what do you guys think? Fuel filter? Injectors?
Thanks,
Mike
94 Camaro a-4<br />Z-28 Exhaust<br />gutted cat<br />Just not enuff!
mine has been missing a lot, and running really lean. all due to a faulty MAF sensor. getting it replaced next week, sounds like you have a similar problem
Yeah I guess it could be a MAF sensor haven't checked into thator the coils but I will. You guys don't think it could be the injectors doing this? Thanks for the info.
Mike
