<blockquote>quote:</font><hr>Originally posted by FlybyChevy:
As far as I can tell the modern 3800II is a stronger engine in design(block) than the old 3.8 GN motor. The "stage" motors are different racing versions of the 3.8GN motor and are much stronger than the stock engine.
An unknown between the two is the fact that the 3800 engine is even-fire and the 3.8 is odd-fire. What I was told that the 3.8 has a journal for each rod while the 3800 has 2 of the 6 rods on the same journal to make it even-fire and smoother. It may mean the crank in the 3800 motors will break before the 3.8, but nobody has taken the 3800 to those levels yet.<hr></blockquote>
Acually the old 3.8 was odd-fire till about 80-81, then they went to even fire. Also both the 3.8 and the 3800 ultlize the same crank as far as design goes, they both have 2 rods riding on the same journal. The 3800 used a blanced shaft in the lifter vally to help somooth out the 90 degree V6 shutters.
