GM - Cooling System Bleeding - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • GM - Cooling System Bleeding
    COOLING SYSTEM BLEEDING
    All 3800-IIs Except "W" Body
    1) Fill radiator to base of filler neck. Start engine. Place A/C-heater control in any position except MAX. Select highest temperature setting. Idle engine until lower radiator hose is hot.
    2) Increase engine speed to 3000 RPM and then back to idle. Do this 5 times to expel any air trapped in system. Fill radiator as necessary. Install radiator cap. Allow engine to cool. Fill coolant recovery reservoir as necessary.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
  • 187shark
    by 187shark
