Jetchip Scu2000 - FirebirdV6.com/CamaroV6.com Message Board
Jetchip Scu2000
  • Jetchip Scu2000
    Hey Guys,
    I just bought a scu2000 used and I have no idea how to install it because I dont have the instructions. I checked the jetchip website but couldnt find any info. Does anyone know where I can find one? And how do I adjust the dials on the chip? What do each number and letter correspond to? Where exactly to I plug the wire to? And do I just hook up the other wires to a 12V source and the other to ground?
    Thanks
    Whisper Lid, SLP CAI, KN Filter, 3\" HiFlo Carsound Cat, full 3\" mandrel-bent piping, Flowmaster 80s, Casper O2 Sim, BM Tranny Cooler, Vigilante 3300 Torque Converter, Corvette Servo, 3.42 gears, SLP take-off LSD, Manual Fan Switch, & 160 Thermostat.
    man i dont know if i have my instructions but if i find them i will write things down, i dont know why the person didnt send u instructions that is bs. i know the 3 setting for the gears is 3.08 and most people experiment with the modded tire size because the numbers let the rpms go higher and lower for the modded tire size, i think 5 is 3.42 gears so put your stock gear setting to 3 if u had 3.08 and your modded gears to 5 and your stock tire to 3 and modded tire to 5 and see how that works, then if you use the lower numbers for modded tire the rpms shift lower the higher number they shift higher. run one wire to a ground and one to a 12 volt source the scu2000 plugs into the tail end of the tranny
    [ June 07, 2002: Message edited by: bluecmaro96 ]</p>
      Thanks a lot.
      My stock gears were 3.08. My new gears are 3.42.
      Stock tire size is 235/55/16 and new tire size is 255/45/17. And I kind of wait to shift at 6000 rpms. hehe....thanks a lot man.
        yeah stock gear 3 mod gear 5 stock tire 3 mod tir 5 then you can experiment with the mod tire size for the rpm shifts
          Hey bluecam,
          Were you able to find your instructions?
            Can anyone confirm those settings?
              This doesn't really fall under advanced tech.. seems more of a basic help question so I'm moving it to general tech.
              Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
                Here it is:
                stock tire dial 0 - 245 x 50 x 16
                1 - 275 x 40 x 17
                2 - 215 x 60 x 15
                3 - 235 x 55 x 16
                4 - 255 x 50 x 17
                stock gear dial 0 - 2.56
                1 - 2.73
                2 - 2.93
                3 - 3.08
                4 - 3.23
                5 - 3.42
                modified tire dial tire size
                0 - 23
                1 - 24
                2 - 25
                3 - 26
                4 - 27
                5 - 28
                6 - 29
                7 - 30
                F - Default
                modified gear dial 0 - 2.56
                1 - 2.73
                2 - 2.93
                3 - 3.08
                4 - 3.23
                5 - 3.42
                6 - 3.73
                7 - 4.10
                7 - Default
                Email: Preki1212@hotmail.com
                  <blockquote>quote:</font><hr> modified tire dial tire size
                  0 - 23
                  1 - 24
                  2 - 25
                  3 - 26
                  4 - 27
                  5 - 28
                  6 - 29
                  7 - 30
                  F - Default <hr></blockquote>
                  What does that mean?? What do I pick if my modified tire size is 255/45/17?
                    Like i said stock tire and stock gear 3 mod gear 5 mod tire 5 see how that works, for the mod tire settings i noticed that the higher number the higher the rpm goes up the lower number the lower rpm goes up, you have to TEST AND TUNE see whats best for you
                    • Manimal
                      Coil springs
                      by Manimal
                      6 days ago
                    • Manimal
                      Newby here
                      by Manimal
