Do any of you other 4th gen guys have problems with a high mileage car and it's hatch making all kinds of rattling and chirping noises? if so, please enlighten me on how to fix it. if not, then... well... i guess i'll just turn the stereo up louder. of course, that's probably what caused it in the first place. [img]smile.gif[/img]
thanks,
bill
Sold her. :( - 94 Bird, K&N filter, Flowmaster exhaust, WS6 Wheels with Dunlop sp5000\'s all around. Many mods to come. Not to mention 205,000 original miles!!<p>New Ride - White 01 WS-6 M6 (Direct-Flo airlid, flowmaster exhaust)
please disregard my poor spelling. it's been about 2 1/2 months since i've been home from college, so i haven't used my brain much. [img]smile.gif[/img]
Check your defroter connection... that can sometimes come loose and rattle, I just stuffeda piece of electrical tape in there and it didnt rattle anymore. Not too sure if this is your problem, but check...
this isn't my problem simply because... i have no defroster. any other suggestiongs? thanks.
check the hold down for your spare tire. make sure it is snugg and didn't loosen up. mine was making a chirping noise ( sounded like a baby bird in my car) and my spare tire came loose up.
if that is not what is causing the rattle or chirping try adjusting your hacth to close tighter. my hatch rattles but it is because of my stereo ,the speaker box is up agaist the glass not letting it close snuggly.(and not to mention my taillights and every thing else in the back end rattles :D )
94 Firebird 3.4 M5 t-top<br />mods: 3.4 aluminum block, big block hood,custom ram air,cat back exhaust,3 JL 10 inch W0 with a 1200 wat legacy amp, legacy 6 1/2 componet set , pioneer 3 way 6 1/2 ,pioneer 730 wat amp.
u loosen the bolts on the latch assembly and push it down ward then snug up the bolts. pushing it down with cause the gate to latch closed tighter
open your hatch and look right in the center of the car (the area where you would insert key to open hatch). u can see the top of the latch through the plastic panel. pull the back plastic panel off to uncover the whole latch and the bolts. also the side panels would have to be removed to get the back one out all the way.
I was going to say check your spare tire!! My was the same. The little shocks that lift your back window, well one of mine are making a noies it shakes when i drive.
-FLOWMASTER 80 series exhaust dual out,K&N air filter.<br />-Bright Rally Red, 1993 Camaro V6 automatic. No BIG mods yet! But who needs alot of mods when you have 160 hp? Kumho ECSTA Supra 712 tires 245/50-16\'s \"Great tires\" <br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG</a><br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG</a>
The hydraulic lifts (hatch supports) tend to squeak with age also. Get a small of white lithium grease and spread a little where the shaft goes into the cylinder. This may help a little.
My hatch rattles because the two little rubber stops on each end inside of the hatch are shot! They are two little screw in pieces (on the hatch's underside right where the tailights are)that keep the hatch from bouncing up-n-down when you hit bumps. Mine are bigtime beat, and I'm just too lazy to find new replacements.
-Marc
