Running Rich - FirebirdV6.com/CamaroV6.com Message Board
Running Rich
  • Running Rich
    history:
    2000
    75K miles
    could be stock plugs...dont know
    could be stock fuel filter....dont know
    air filter is nasty....probably stock
    wires are 5 months old roughly
    not sure the SES light works, bulb might be out.....getting scanned tomorrow
    O2 sensors.....most likely stock
    Symptoms:
    exhaust smoking slight white
    exhaust smells like fuel
    #3 & #5 plugs black and smells like fuel.
    whats do you guys think?
    car is running rich
    [ October 13, 2004, 12:22 AM: Message edited by: BLLDOGG ]
    2000 3.8 A4 Pewter Camaro
    SES light or any codes?
      no light....
        If you are not sure if your fuel filter/plugs are original, well...how long have you had the car?
        When you turn your key on (not engine) does the SES light come on?
        2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
          75000 miles with stock air filter?!?
          [ October 13, 2004, 12:24 AM: Message edited by: 98Camaro3.8 ]
          Matt
          1998 Mystic Teal Camaro M5
            ummm...im stupid, i swear. yes, the ses light works. i look at it everytime i turn the car on. no SES light is going off.
            yes, not sure if anything is original or not. filter is dirty and the fuel filter could be stock...dont know but the fuel filter wouldnt make it run rich so.....it was going to be replaced unitl this problem arose
              </font>
              • Fuel pressure high - The system will go rich if pressure is too high. The PCM can compensate for some increase. However, if fuel pressure is too high, the system may go rich</font>
              • Fuel injector(s) faulty</font>
              • Check the EVAP Canister for Fuel Saturation. If the EVAP Canister is full of fuel, check canister control and hoses</font>
              • Disconnect the MAF sensor and see if rich condition is corrected. If so, replace the MAF sensor.</font>
              • Check for a leaking fuel pressure regulator diaphragm by checking the vacuum line to the fuel pressure regulator for the presence of fuel.</font>
              • An intermittent TP sensor output will cause the system to go rich due to a false indication of the engine accelerating.</font>
              Matt
                thanks but alittle to technical for me [img]redface.gif[/img]
                time to go studying on how to do all this :(
                would a bad O2 sensor(s) cause this too?
                  Unburned fuel will be black smoke, not white.
                  SPend $30 bucks and give that poor car a tune up! It needs it from your parts desription.
                  Sounds like you are burning oil from somewhere.
                  1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
                    its more gray. im thinking the smoke might be just from it being cold cause thats what it looks like. im more worried about the fuel....right now
                    yeah i know i need that stuff changed. trust me. im not letting this stuff fall to the side. i just dont have the money. after christmas though. my mom told me my car is going to be living in shops getting things fixed like speakers and ignition cylinder and other little things i dont want to do....
                    [ October 13, 2004, 06:17 PM: Message edited by: BLLDOGG ]
                      Have those injectors checked for leaking after the engine's shut off...
                      Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
                        1 can of BG 44k would do some good.
                          can i do this at home or do i have to take it to a shop? if i cant do it here. i would rather replace them here.
                            what is BG 44K? i have never heard of this stuff
                              If you said #2 & #5 I'd say coil, but doubtful you had 2 go at once. Replace the air filter and spray out the butterfly and into the intake with some TB cleaner.
