Running Rich - FirebirdV6.com/CamaroV6.com Message Board
Running Rich
  • #16
    Your fuel filter WAS CHANGED at some point if you have no ses light. I had to have my injectors cleaned and fuel filter replaced at 40k miles because they were so dirty it was causing the engine to idle rough when first started.
    I would check the plugs and wires. Replace that filter with a K&N, that will help a little. Also consider the possibility you may need a little tuning with your mods: you do have headers, cat, and muffler. That plus no tuning might be making you run rich.
    • #17
      Originally posted by BLLDOGG:
      </font><blockquote>quote:</font><hr />Originally posted by L32Projekt:
      Have those injectors checked for leaking after the engine's shut off...
      can i do this at home or do i have to take it to a shop? if i cant do it here. i would rather replace them here. </font>[/QUOTE]Well, you'd have to get them tested at a shop or you can buy new ones. I'd suggest doing all the easier checks before this test...
      Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
      • #18
        thanks. go read my new post in the exhaust forum. i hear something interesting
        2000 3.8 A4 Pewter Camaro
        • #19
          if my air intake sensor went bad, it would cause my car to possibly run rich right?
          • #20
            No, I don't think so, it just monitors intake temps and adjusts timing to stave off possible detonation. I'd check O2 sensors before that.
            • #21
              k, thanks. i was just wanting to think of everything [img]smile.gif[/img]
