Intermittent a/c problem - FirebirdV6.com/CamaroV6.com Message Board
  • Intermittent a/c problem
    This is a strange one.
    Went to the GREAT Ontario Camaro Nationals this weekend (took my girlfriend and her daughter). On the way up there (from Pittsburgh, PA) the a/c was working great until I got up to around Erie, PA (about 120 miles from home) and it stopped blowing cold. In fact, it was blowing warm air. I kept alternating between vent and a/c the rest of the trip (with the dial at max cold) but it made no difference. On either A/C setting it would only blow warm air.
    Here's where it gets weird. After the car would sit for a few hours, I could start the car and the a/c would work for about two or three minutes before it would all of the sudden (not gradually) begin to blow warm air.
    Since I arrived back home I took the car on two short trips each about ten minutes long and the a/c worked fine the entire trip both times.
    I feel funny taking it to the dealer because it now appears to be working and they'll probably tell me that all is working fine.
    Has anyone else had this same experience and, if so, what was the problem?
    \'01 Camaro M5 1SA \"Lightweight\" hardtop, Bright Red, Ebony cloth, FRA, Whisper Lid, B&B cat-back, Torsen 3.73 LSD, HPPIII (93 octane setting)<p>\'00 Camaro SS M6 T-Top, all GM and most SLP opts., Bright Red, Ebony leather, 4.10s, SLP long tubes, Loudmouth, CNC Stage II H/C, etc.
    In my car i just go by the A/C car store and they shoot my car up with some cold stuff not sure what exactly it is but makes my air blow nice and Chilly Willy! :D
    <a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
      With it being so new, it would be adviseable to have a pressure check done and a compressor check done on the A/C system by your dealer.
      It might be that your system is low on freon and needs to be recharged - or the pump could be locking up for some odd reason.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        Just a quick correction to what Dominic said it wouldn't be freon it would be the rj-134a refrigerant, same thing as freon except it doesn't harm the environment. Not trying to be a smar a** or anything but I just wanted to let you have the correct info.
        1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
          right near the refridgerant container, there's a pressure sensitive switch (open when pressure is good, closes when pressure gets low) Check the wires coming off this switch, and the socket they plug into.
          these activate your ac compressor and it sounds like your compressor isn't starting once your car warms up...
            It's either that pressure switch or your compressor is overheating. It shuts down on it's own when that happens.
            \'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
              that what is happening to me..anyone find out what is going on???
              Landon<br />2002 Black Z28<br /><a href=\"http://community.webshots.com/user/02blackzzz\" target=\"_blank\">http://community.webshots.com/user/02blackzzz</a> <br />SLP Whisper Lid, Chip, Magnaflow Catback, SLP Y-Pipe<br />Former owner of a White 3.8 RS<br /><a href=\"http://www.cardomain.com/id/allwhiters97\" target=\"_blank\">www.cardomain.com/id/allwhiters97</a>
