Front light problem - FirebirdV6.com/CamaroV6.com Message Board
Front light problem
  • Front light problem
    I have problem whith the front head light they will go on but they wont pop upp if you know what i mean could it be any relay or some fuse?
    maybe its major problem? i just bought the car
    the swede / Håkan
    it could be a bad fuse or relay.to find out just gett someone to turn them on,and u test the power wire to the head light door motor and see if u get the power pulse to the plug. In case you not sure were the head light door motor plugs r they r under the hood next to the manual control for the head lights one on each side.which r right next to the head lights. if u do get a power pulse then u might be looking at 2 new head light motors. in which i have not seen both go out at the same time but could be possible.
    94 Firebird 3.4 M5 t-top<br />mods: 3.4 aluminum block, big block hood,custom ram air,cat back exhaust,3 JL 10 inch W0 with a 1200 wat legacy amp, legacy 6 1/2 componet set , pioneer 3 way 6 1/2 ,pioneer 730 wat amp.
      Thanks for the tip I just have to jump back i the garage again and check it(hope is just a fuse) Have a nice day
        gee the swede is a nice guy...
        [img]smile.gif[/img]
