problem with wire installation - FirebirdV6.com/CamaroV6.com Message Board
  • problem with wire installation
    alright so i got the 8mm taylor spiro wires, im trying to put the damn things in and the boot connecting to the plug or injector, whatever it connects to wouldnt fit in all the way, what the hell???
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    First off if you are not sure whether the boot fits on the plug or injector then maybe you shouldn't be doing a plug wire swap.
    All you need to do is listen for a snap when sliding the boot over the PLUG and then give it a little tug to make sure it's on securely. Don't forget to use the dielectric grease as well.
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
