car has 56k miles. i have never replaced PCV... - FirebirdV6.com/CamaroV6.com Message Board
  • car has 56k miles. i have never replaced PCV...
    should i do it? is that the part above the fuel rail on the passanger side of the intake manifold?
    what is the pcv for ?
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    PCV = Positive Crankcase Ventilation
    Check it according to the haynes manual and that will determine if you need to replace it.
      I would change it if I were you. Cheap maintenance. It's to bring the gases, from blowby, in the crankcase back into the intake to get it burned up again. If it's clogged and not working the gases in there will have a possibility of creating leaks from the build up of pressure. It will seep thru weaks spots in gaskets causing premature leaks. It will also cause oil to sludge up. Of course, this is just worse case scenerio. You're supposed to change it at 30k. I didn't change mine til 70k and when I shook it, it's still good, but I changed it anyways since I got it.
      [img]graemlins/burnout.gif[/img]
      1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
        Jsut change it, its only like $2-3 and 5 min of no tools required work.
        Those 5 minutes include getting off the couch and going outside.
          Even cheaper than that.
          Just replaced mine this weekend = $1.87 @ the local Walmart.
          There is a little rubber gasket around the old one. Either reuse it or you will have to get one at a auto parts store.
          --Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
            where is it located?
