do you have to reuse that off white housing or can i wire tie the pump to the bracket? and if i dont use the housing what do i do with the two rubber lines that are for the feed line and the vent that goes on the housing, the two rubber hoses that attach to the housing, what do i do with them if i dont reuse the housing? will i have problems if i just wire tie the walbro to the bracket rather than reusing the housing? i cant get the old pump out it wont pull apart, would it hurt if i just let those other two rubber hoses hanging since the housing isnt there?
anyone who installed walbro please help asap
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...13 hours ago
