Why is it that when i step on my breaks and slow down my lights dim and my rpm's drop (to like 500 or 600) then after i stop the lights go back to the way they should be and sometimes the RPM's will go up but sometimes they stay at 500-600
lights dim when i step on brakes and slow down
Its the stupid way the voltage regulator works in these cars. Some are worse than others, like my old Firebird.
My new Camaro doesnt seem to have this issue really, but the firebird did from day 1.2002 5-spd NBM Camaro
Details: www.1lev6.com
(GAWD I love this site!) I haven't asked or posted any tech questions before but I am starting to notice a few things wierd about my car and you guys already have asked them! It's a relief sorta, to know others are having the same problems as me.
I was curious about the lights dimming too. My 93 bird didn't do that. But this one I have now, does. I'll hit the brake and the headlights will dim out for a bit and come back up. My volt meter drops a bit too.
Is this normal?~02 W68 Crow-Black Bird~<p><a href=\"http://www.cardomain.com/id/dravensbird02\" target=\"_blank\">scratch n sniff</a>
This happens to my car as well, been doing it since the day I drove off the lot, with 51 miles on it. Dealer service department says, that the way the car is???? OK, lol. Anyways, seems like it is the electrical system or the way it set up.!!!TOWN IDIOT!!!
Mine does it some times.95 \"Deep Metallic Purple\" camaro<br />160 hp <br />1/4 mile in the 17\'s at 86 mph<p><a href=\"http://community.webshots.com/album/91867924TYiSkT?515\" target=\"_blank\">http://community.webshots.com/album/91867924TYiSkT?515</a>
I'm almost positive it's the voltage regulator. Our cars use a generator (uses an electromagnet instead of a natural magnet to create the magnetic field, and the regulator uses that to control the voltage generated.
The generator puts out ~14V, your battery puts out 12. So, when the regulator shuts the generator off, the system drops to 12V.
Also, the PCM will test the EGR valve right around the same time (below 1500 rpm, no throttle, coasting), so it may be drawing on the system.
Basically, it's an annoying little quirk of the system.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
