I am wanting to check out how my engine is doing. I was going to doa compression test and I wanted to first doa vacuum test but I dont know how on a new car? can it be done without a scan tool? I looked but didnt find a fitting to connect a guage to? anything else that I could do to check out the condition of my engine? thanks.
checking engine out?
All you have to do is disconnect a vacuum line that has vacuum all the time, and connect that line to your vacuum gauge. If you get vacuum at idle, that line should be good enough.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by Fredless:
go to autozone and get it scanned for free.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
used oil analysis by someplace like Blackstone Labs, maybe? It could show bearing wear, a fuel system problem, a head gasket leak, etc. before they become obvious [or so they say].\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
if you had ascces to a scanner that showed you live data you can figure engine vacuum using MAP sensor voltage.
but look for 19Hg of vacuum when your gauge is hooked to the intake at idle1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
