I have a 3.4l V6 in my 95" maro and have a stock 195 degree thermo. I want to change this to a cooler one in hopes of gaining a few extra hp. The only question I have is should I go with a 160 or a 180? Will the 160 cause problems with the PCM? I know the 180 degree wont cause problems but im a little skeptical about a 160. It just seems to me like it might could cause a few problems in a fuel injected car. Also could anyone with knowledge about the 3.4 tell me if the PCM operates in much the same way as the 3.8 does in the engine tech section? Sorry for alot of questions but im new here and ive been reading alot and just want to squeeze the most out of my little 3.4.
Should I replace Thermo?
The 160 thermo doesn't cause problems with the 3.4L- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Should be no problems going with a 160° thermostat since you're down south. For the northern climates I'd stick with the 180° thermo for the winters.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
The 160* thermo is pretty worhtless unless you have some way of changing your fan settings so they come on at a lower temperature. And you don't gain any power with a stat swap, you just don't lose as much when your engine is hot.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
And you don't gain any power with a stat swap, you just don't lose as much when your engine is hot.Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
When your car is actually moving its probably not close to overheating anyways unless you have some other problem. So getting your engine temperature down while it's sitting still is the purpose of cooling system modifications am I wrong? It's not going to hurt adding the stat without tuning, I'm just saying it would be lots more beneficial if you had both.
And by not gaining any power I meant you won't actually increase your maximum potential with a stat swap, but it could help you stay closer to that max by keeping your temperature down.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...2 days ago
