burning oil and performance question - FirebirdV6.com/CamaroV6.com Message Board
  • burning oil and performance question
    it is a sad truth that i am burning oil, but my question is: is my performance supposed to be a whole second slower with such problem? would my mph suffer with such problem or is this much more than what i think it is? last time at the track i could only muster 88/89 mph with horrible ETs. much slower than stock and i even got an 83 mph. i added the headers and gutted the cat since my last visit, but my car is now smoking more than a cheech and chong movie.
    when i get my seal? ring? whatever it is fixed, should i gain my lost sec. back and should my mph go back to the 90s?
    or does it sound like i have more problems than boy-loving catholic priests?
    tanks
    6s.......under the hood or under the belt, they just dont cut it.
    <blockquote>quote:</font><hr>Originally posted by nino:
    tanks
    <hr></blockquote>
    LMAO
    nino you need to ditch that ****.
    My buddy's 01 formula burned oil, and he still ran 12.8Xs with a lid, pulleys, and cutout before he got the new motor. Don't know if that helps or not, the cause of burning oil may be different on yours than his.
    LS1! LS1! LS1! :D
    Scott
      scott, i put too much into it to just throw it all away. i always said that when i blow my motor i would just do the V8 swap, but i never meant at 35,000 miles.
        would a valve seal leak cause my trap speeds to be so poor?
          Do a compression check Nino. That will tell you if its the rings..
          If it IS the rings I'd point to your mechanic.. what did he F up? Your car would be the FIRST 3.8 that I know of to have ring issues.
            <blockquote>quote:</font><hr>Originally posted by Magnus:
            <hr></blockquote>
            wurd
            compression test to test rings. if it checks out, then Id investigate on the valve seals.
            if it was leaking enough though the seals I see it fouling the plugs then yea it might kill your performance.
