Swapping PCMs - FirebirdV6.com/CamaroV6.com Message Board
Swapping PCMs
  • Swapping PCMs
    How difficult is it to swap a pcm and how do you do it? I need to know for my rear-end swap I'm doing shortly.
    <a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
    Swapping a pcm is easy pie man. Just gotta disconnect the two bolts, take off the two connector attachements, and pull that mother out. Its very annoying to pull out, but you can do it, just give it hell [img]smile.gif[/img] Make sure you disconnect the battery first though! If you need help on the rear-end swap I just completed mine, aol me at Zaknafein6
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
      Make sure you are careful when you are removing the two bolts on the connectors, if you do it the wrong way or if your too rough it will break the conneters and you really be sol. And also make sure to remove the two bolts on the casing the PCM is sitting in and then move the whole thing to the right and try toget it out. You might have to loosen the water guard under the windshield there because I did.
      In case you didnt know the PCM is in the upper left hand corner of the engine compartment, easily visable due to all the wires going into it. I fuxored my hand up doing this so be careful all that metal in there is sharp.
      for fun do a seacrh for: PWNED by my PCM, it details in length what happened to me. [img]graemlins/dunce.gif[/img]
      [ April 01, 2003: Message edited by: Dirty8-un-Dreds ]</p>
      1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well see
        Why are you replacing the PCM? I installed another rear in my car and I didn't need to change anything other than the emergency brake cables.
        -Marc
          hockeyman
          he probably is changing gears brother
            i did my 99 in less than 5 minutes....easier than doing a lid...oops i noticed that you have a 96, i think those ones are harder
            98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
