manual fan switch for 3.4 - FirebirdV6.com/CamaroV6.com Message Board
  • manual fan switch for 3.4
    i have done searches on this board and on camaroz28.com's board but i cannot find info on how to perform the manual fan switch mod on a 3.4l engine. i have seen a bunch of things on the 3.8 but is there anything for the 3.4. thanks for the help
    94 Camaro 3.4l A4<br />K&N FIPK<br />Flomaster 80-series Muffler<br />TB Coolant Bypass<br />Power Antenna
    It's easy. Here's what I did.
    1. Buy some wire and a switch.
    2. Locate relay box under hood. (by air box)
    3. Take off plastic wing nut and cover.
    4. Relay box panel (where ralays plug into) is held on by plastic tabs. Separate it.
    5. Find the relay that controls the fans and connect a piece of wire into into the bottom of it that you have exposed.
    6. Mount switch and run the wire to it.
    7. Run another wire from switch to a power source that is always hot. (I used air pump)
    note: Unless you insulate wire, don't run it the length of the hood. I mounted mine right by the box and have had no trouble at all with it.
    Josh-
    \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
      how much would this cost? and would I really need it? my car ran pretty cold on a 1000 mile / 13 hour trip. It went about middle, I'll go check how hot that was later and let ya know.
        Wire from Auto Zone= $2.99
        Switch = $1.99
        Misc Connectors = $1.99
        Less than $7.00
        $10.00 tops if you decide to go with a fancy switch with an LED in it.
        My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
          There is an alternate way to doing this also. Locate the wire labled "J" up by the pcm. It is a green wire and the label is on the wiring harness. Tap into this wire with a scotch lock, run this tap to your switch. NOw run a wire from your other post on the switch to a ground.
          Thats it.
          As for if you really need this mod... well I guess if you're sitting in traffic alot, it might help. But if your mostly cruising down the road at resonable speed you probably dont need it. It is more of a "keep your car cool at the track" mod.
          email me for help or pics
          \'95 Med. Quasar Blue Camaro 3.4 A4<br />Bunch o\' mods<br /><b>10.18 @ 67.60 mph 2.22 60 ft (1/8 mile)</b> <br /><br />-1986 Camaro with a carbed 350<br /><b>8.53 @ 81.45mph 1.8 60\'</b><br />AIM CamaroL32
            much easier
            5. Find the green wire that controls the fans and connect a piece of wire into it.
            6. Run That Wire To A Switch
            7. Run another wire from the switch to a ground
            :D
            [ July 11, 2003: Message edited by: TurboKillaZ ]</p>
              http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=010106
              I followed this and it works great.
              1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
                6 days ago
