Right turn signal just stays on, so does the taillight...
Like it said, my right turn signal just stays on when I turn it on to make a turn, It doesnt blink. My tailight also just stays on. I checked my hazard switch, with it both signals and lights blink properly. Anyone know why its doing this and how to fix it? I really would like to get it fixed asap.
Thanks in advance
2000 3800 II V6 Firebird<br />various small mods, bigger stuff later.
In my experience, that happens when you have a bad bulb. Replace them on that side, one at a time, until it works. After you've done that, then look at the flasher module if it still isn't working.
\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
Originally posted by phoenix6: Like it said, my right turn signal just stays on when I turn it on to make a turn, It doesnt blink. My tailight also just stays on. I checked my hazard switch, with it both signals and lights blink properly. Anyone know why its doing this and how to fix it? I really would like to get it fixed asap.
Thanks in advance
Probably a blown bulb in the front right turn signal... They tend to go out easy as they're the first to get wet...
Just so you don't try and change the bulb from abve- under the car there's a door cut into the plastic. Just remobe the screws, and you can reach the bulb housing from there
If you can change all the bulbs at once, when I first got my car it did the same thing, I changed one bulb then the other side went out, then changed that one and one in my taillight went out. So to save you the trouble id just go ahead and replace all at once.
Originally posted by 98goldbird: I actually like it better when my turn signal doesnt blink. It just stays brightened up. [img]graemlins/rock.gif[/img]
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
