MAF sensor - FirebirdV6.com/CamaroV6.com Message Board
MAF sensor
  • MAF sensor
    Hello,
    I'm french and I have a problem with my 99 camaro 3.8L :( .At a moment my car had misfire.Went I go back home i had the code 0102: maf air flow low input.When i have openned the hood i have remarked that the Maf sensor hood was broken.After, when I inplugged the Maf sensor the car run great and when I plugged in the car doesn't start.Now the car doesn't work with the maf inplug or plug in.I think the throttle body is in close position.
    Do you think this is really the maf sensor?
    Thanks
    you blew a fuse -.- check all your fuses under the hood.
    brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
