My car has a mind of it's own... - FirebirdV6.com/CamaroV6.com Message Board
  • My car has a mind of it's own...
    Alright, this is really weird, and i'm not even sure where to start looking to fix it... here's what is happening.
    Everytime I hit the keyless entry on my car, my headlights pop up, and then close again, but on the left headlight, there is a loud noise for about 10 seconds after they close again. The noise also happens if I just open and close the headlights normally. It sounds as if maybe the motor is jamming or something. With the hood up, I can see that the driver side headlight shakes violently when the noise happens.
    Any ideas on what is happening?
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
    The usual gear failure?
    Matt
    1998 Mystic Teal Camaro M5
      yeh, thats the typical gear failure as far as I can tell. Mine did odd stuff when my gear went out. Thats where I would start
      http://www.bfranker.badz28.com/headlightfix/
      thats the cheapest way to fix it, its not hard either
        This is the easiest fix that makes you feel good after you fix it. I cant stand that annoying sound. Just rotate the gears by spinning the motors manually so that your motors are using the other side of the gear to raise and lower the light. Read the fix. Peace
        1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
          ok ive gone through this...its the headlight motor...you need a whole new one,i replaced EVERYTHING but the motor and it still did it,i replaced the motor..and it stoped.
