i have read and read on here for a while now.. cant find much.. i am gettin no power to my fuel pump though the grey wire.. i ran a wire to my pump from battery and burnt up my pump now had to buy new pump... where does that gray wire run and what would couse it not to get power?? any help is greatly appreiceted
No power to fuel pump
did you check your manual for a chart of the fuses, I had to with my 97 3.8l, but I am not sure about a 3.4. There should be a fuse though
There's a 15 amp fuse in the main fuse block. Fuse #5. Found it in both my Haynes manual and a downloaded owners manual for a 94. [img]tongue.gif[/img]
You say there's no power through the gray wire. Does the pink wire going into the relay have power?
The gray wire runs from the Fuel Pump Relay to both the fuel pump and to the PCM (to tell it if the pump's on).
The pink wire into the relay is from the Fuse.Matt
1998 Mystic Teal Camaro M5
