Pictures of something that needs fixing HELP - FirebirdV6.com/CamaroV6.com Message Board
  • Pictures of something that needs fixing HELP
    http://img.villagephotos.com/p/2005-...6/DSCN0589.JPG
    http://img.villagephotos.com/p/2005-...6/DSCN0599.JPG
    http://img.villagephotos.com/p/2005-...6/DSCN0590.JPG
    http://img.villagephotos.com/p/2005-...6/DSCN0602.JPG
    http://img.villagephotos.com/p/2005-...6/DSCN0595.JPG
    http://img.villagephotos.com/p/2005-...6/DSCN0600.JPG
    This is some kind of a leak in the rear. ITs also my muffler and what looks to be a leak in the muffler too. And is it bad for all that to be that rusty? If yall could analyze these pictures and tell me what yall think.Thanks
    [ May 23, 2005, 02:54 PM: Message edited by: the bandit ]
    1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
    farked
    Matt
    1998 Mystic Teal Camaro M5
      exceeded bandwidth...
      I really really hate geocities.
        fixed bandwidth issue..
          Looks like your pinion seal is leaking. Seems to be a common occurance.
          [ May 23, 2005, 03:04 PM: Message edited by: 98Camaro3.8 ]
          Matt
            yep been there done that on my 94...
            You can repalce the seal, I think its like $15-25, or you can just swap in a new rearend...
            if you have a stock rear, I'd consider upgrading to a z28 rear.
              how bout the rust and the muffler leak picture
                Rust is no big deal. It's a 96 with the stock muffler, it's gonna happen.
                The fluid on the muffler is probably oil from the pinion seal leak flowing back onto it while driving.
                Matt
                  yup..mine does all the time..whether i fix it or not it will still leak..it leaks REALLY slow now so i wont even bother replacing it..i just top off the pinion fluid every once in a while
                    it sucks that 90% of fbodies get this.....three questions.
                    1. How do I check the pinion fluid.
                    2. This questions seems easy but just to make sure how would I know if I have a 1 piece or 2 piece drive shaft. Thanks
                    3. Should I even replace the seal since it will leak again?
                      Remove the fill plug on the top of the passenger's side of the pumpkin. Stick your finger in and see how far down it goes. Fluid should be right to the top of the hole.
                      Is there a big U-Joint in the center of the driveshaft, or is it one long solid piece?
                      Yes. Just because it leaks again for some people is no reason to not fix it on yours. They could have other problems that are causing it to leak.
                      Matt
                        Just to warn you, its not an "easy" fix... I would look into the option of replacing/upgrading the rear.
                          upgrading to what....I have 3.42 gears what else would i upgrade?
                            haha nevermind didn't even look at your sig...
                            Might be worth fixing it, its a pain in the ***, and I think you will likely have to buy specialty tools.
                            I know I had too... when I ran into this problem... and I already trashed something in my rear... so I said **** it and upgraded to 3.42s, LSD, and disc brakes, was cheaper then fixing my own.
                              Upgrade to my 3:08's so I can have your rear end [img]smile.gif[/img]
                              Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
