Is this... - FirebirdV6.com/CamaroV6.com Message Board
Is this...
  • Is this...
    ...the PCV valve. I have the SLP CAI, so the IAT sensor is on the left side of the intake elbow (of course)...if you move up towards the 3800 SERIES there is a tube/cable with a little black plastic piece that connects to the engine.
    Is this the PCV valve? I need to know because someone said to take the PCV valve and shake it.
    If that *IS* the PCV valve, I need to replace it because it didn't rattle. So I just removed it, shook it and put it back. I'm guessing I just remove it from the tube, and then put in the new one and put that one in?
    LOL...sorry to ask such a dumb question guys. THANKS.
    http://www.fbody.com/members/Dojo2000/PCV.jpg
    cut&paste link
    The PCV vavle is located under that metal plate on the intake manifold labeled "PCV", yours is probably worn so you can't see the letters :D
    you should go to your nearest parts store and pick up a Haynes repair manual, they are very, very helpful.
    [ August 08, 2002: Message edited by: Dojo2000 ]</p>
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      Thank you so much...I was about to take a picture of my engine and do the same thing. :D
