I have an annoying exhaust rattle with a strange characteristic. When I start my car when it's cold and start driving..it doesn't rattle at all. But once the car warms up, the rattle continuiously gets worse. I'm pretty sure it has to do with the exhaust, but I'm not positive. Any ideas?
strange rattle
I had that too. My rattle was the exhaust's I-Pipe. There is a slide-connection on the exhaust behind the converter. Look between the s-bend and the setion that goes over the rearend housing...you'll see it! When my car heated up, it would rattle like crazy! I welded the living sh*t outta that connection, and I don't have that rattle anymore.sigpic
But it coudl be possible if it gets loose it will hit the little crosssmember thingy.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
