AC Removal - FirebirdV6.com/CamaroV6.com Message Board
AC Removal
  • AC Removal
    I was considering removing the AC equipment on my Camaro. Basically cause I've had the car for three years and have never used it before and I don't intend on selling the car either.
    Would doing this mess with the timming or anything like that?
    1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
    youve never used your A/C!!!! you live close to me and there was a heat index of 112 for 10 days straight here!! wow I had it full blast!
    also, you should look around in the regional section some... theres sometimes some v6 fbody get togethers around here... prolly one before people get back in school and such!
      Thats cool. It kinda sucks always gathering with the 5.7L guys, and it's a pain to try and keep up. :D
        It won't affect timing, a/c system and timing are completely seperate systems.
        If you yank the ac compressor then you either must have a custom bracket with a free spinning wheel or shorter belt.
        I had a custom bracket made when I deleted my power steering.
        Magnus is the only person I know who deleted a/c in a v6, you might want to check out his site if he has anything there.
          I took my AC out to make room for my turbo. I just had to get a shorter belt. works fine.
          New Car--- 2000 Trans Am M6--SLP Lid, K7N Filter, 160 degree Thermostat, Loudmouth Exhaust, Smooth bellows, MAF ends, ASP Pulley, 4.10 gears, Y2K Chrome Vette Wheels, 2\" drop.. More to Come<p>Dyno <br />325 RWHP <br />325 RWTQ<p>Cardomain Site <a href=\"http://www.cardomain.com/id/formulao96\" target=\"_blank\">www.cardomain.com/id/formulao96</a>
            I took mine out when I installed my headers. GM makes an idler pulley for cars not equipped with AC. I will try to find a part number and repost.
              The part number for the idler pulley that would replace the AC on the 3.4L V6 is 10115875 and you would need a belt that is 1954mm long (76.9").
              For the 3.8L V6, I need to see a VERY good pic of the AC bracket and compressor while on the car. The GM parts catalog is a little odd with this system and it's tough to make out what all you would need. I am pretty sure that you would need the following, but would like to make sure with some pics...
              24503454 - Belt Idler Pulley Bracket
              24502989 - Pulley
              24503247 - Belt - 2114mm long, 6 Rib (83.2")
              As soon as I can get some good pics, I will be able to make sure that this info is correct.
                Anyone?
                  one word... crazy
                    Do you ever plan on selling the car? Or trading it in? Unless you're planning to get super serious about racing, i'd leave it in.
                    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
