I am thinking to replace the thermostat. What's better, the 180 or the 160 degree?
160 0r 180?
The 180, because unless you have programmed your computer the 160 will be too cold and it will set off the SES light.
Just put on the 180 and a manual fan switch for the best results. [img]smile.gif[/img]2002 Z28 A4
SLP Lid | TSP Rumbler | P&P Throttle Body | No Cats | 3.42s | M/T Drag Radials | No Front Sway Bar
12.76 @ 108.42 w/ 1.90 60’
if its hot where you live all the time get 160. if it gets cold you may have a problem with the ses light as said above. I live in florida and have a 160 and I do just fine [img]smile.gif[/img]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
thermo is a piece of cake, not sure about the switch though, i dont have one\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Look for manual fan switch instructions, there's a step by step list here with pictures. Search for "xious".Matt
1998 Mystic Teal Camaro M5
I have a 180 drilled stat from ZZP and I'm in florida. Love it, it just takes a bit longer to heat up now..especially back in winter.
It only runs about 5-10* cooler now on the interstate, once you get in traffic though, right back up to 210.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Although it's been discussed, I'll shed some knowledge...
do NOT get a 160* thermostat if you have a later 01 or ANY 02.
There are better ways, albeit probably more expensive, of helping out your cooling system then just plugging and chugging with a 160* thermostat.
Here's what I have found works best - Mind you, I live in cincinnati Ohio, where it gets to 100*+ in the summer time and -20 at points in the winter.
First - Change your coolant mixture. I ran 75/25 water/coolant ratio to help with the efficiency. The little bit of coolant kept water from boiling (or help keep the temp down), and also the coolant works as a rust inhibitor - water on iron heads will rust out over time).
Second - Manual fan switch. I wouldn't bother with a 50 dollar one, I used 6 bucks of materials and put up with the SES light whenever it might have come on.
That being said, I ran a manual fan switch, 75/25 coolant and a 180* thermostat, and unless I was in a traffic jam in the middle of the summer, I never got above 170-172* on a nice spring/fall day cruising with the fan switch on, it'd hardly go past 160. (autotap logging)
hope that helps.2011 Camaro LS 6M, in black.
^^^ word. 160 = bad. 180 is just fine. My car sits at about 170 when moving on a cool day. My fans come on at 200 and cool it back down to about 175-180..
I think with a 160 your car will stay in open loop mode or something like that which is bad for mileage. Open or closed loop, I can't remember.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
Look at it this way... Whatever MPG you're getting now, cut it in half and thats about what you'll get...1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
it never gets cold here so I never have that problem, the coldest it gets is like 30 and thats rare [img]smile.gif[/img]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
One more thing. Some of you said that an 160 will be bad for 01 & 02's. The mine one is 99. Is it bad anyway?Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
