trouible code 1652........? - FirebirdV6.com/CamaroV6.com Message Board
  • trouible code 1652........?
    what does this code mean, what causes it. I looked it up in the search and it said the code was " powertrain induced pitch circuit" or somthing. I hvae no clue what that means.
    jp
    1998 Artic White M-5<br />K&N filter, whisper lid, undercar ramair, Dis-4, MSD 8.5mm SC, bosch plat 4+, BMR STB, Jet stage 2, Poly tranny mount, B&M Ripper, 1le DS, 1le Pan hard rod and lca\'s, LSD, hi-flo cat, flowmater, Kumho 255/50/16, and centerforce dual friction clutch.<br />(E.T. ?, but I beat a 15 sec flat integra by 3 cars in 3rd gear and pulling)<p> <a href=\"http://www.geocities.com/fbodies9870\" target=\"_blank\">http://www.geocities.com/fbodies9870</a><p>*****CAR TOTALED*****<p>2002 Artic White z28 A4 Loaded
    That list in the archive has it listed wrong.
    P1651 Fan 1 Relay Control Circuit
    P1652 Fan 2 Relay Control Circuit
    Just means your fans are running when they're not supposed to. The PCM knows they're running and hasn't signaled them to. If you have a manual fan switch, its because of that, if noy then it probably has something to do with your Jet chip.
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      thank you. its the manual switch. makes sense now.
      jp
