engine removal - FirebirdV6.com/CamaroV6.com Message Board
engine removal
  • engine removal
    does anybody have any experience taking out the 3.8l out the top with a engine hoist?
    so far i have everything taken care of as far as connections, hoses, and transmission, but was wondering how people pull it out with the hoist, should i just use chains on the two corner lifting mounts?
    will lifting with chains bend the lifting mounts inward since they look pretty flimsy?
    is there an easier method to pull out the engine without pulling it from out of the bottom of the car?
    not trying to sound stupid but i could not find much info on how to pull the engine and the manuals that i have dont talk that much on the 3.8L, any info would really help
    3\" Eldebrock catback exhaust<br />rksport powerdyne<br />pacesetter headers<br />VS cam,compcams pushrods,ls1 valves,5 angle valve job,p&p,<br />and total seal piston rings<br /> <a href=\"http://www.cardomain.com/ride/804031\" target=\"_blank\">http://www.cardomain.com/ride/804031</a>
    go ahead and pull the radiator. SOme have removed form the top w/o doing it, but why take a chance. The lifting ears work, as that's what I used to dropthe 3800 in my car. The most funnest part of this operation is putting it back in.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      i have taken out the radiator and the condenser, and the top of the intake manifold
        but will those lifting mounts bend? and should i use chains to pull it out?
          use the lifts, OR you can pick any of the multiple thick bolts on the front of the block or head mounting things up to put the chain on. They may look flamsy, but they are there for exactly that purpose.
            can't you just lift the front of the car up and leave the engine just sitting there?
            99 WS6
            Originally posted by camaroextra
            tears are great lube, but its hard to get a girl to cry onto her own ***.
              that would be similar to picking up your bed and moving it to get to a shirt that is underneath. it is easier to move the lighter part. plus you would need to disconnect everything and have the engine hoisted in the air to do it, why not just lift the engine then?
                Originally posted by mike h:
                </font><blockquote>quote:</font><hr />Originally posted by shock_core:
                that would be similar to picking up your bed and moving it to get to a shirt that is underneath. it is easier to move the lighter part. plus you would need to disconnect everything and have the engine hoisted in the air to do it, why not just lift the engine then? </font>[/QUOTE]Have you pulled the 3.8 out the top? It may be somewhat less work, but it is by no means easy. I did it last spring, and it was a hell of a job. Its a REALLY tight squeeze between the cowl and the K-Memember.
                1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
                  It wasn't that bad, I have afew pics on my cardomain site. Loosen the k a little, remove the TB, radiator, and fans, and viola'.
                  95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
                    Take off your coil packs and headers if you can..
                    Jeff ..
                    1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                    2002 WS6 T/A.. Bolt ins..448rwhp
                    2009 G8 GT.. Vararam intake, GXP axleback
                    1998 Corvette.. Vararam intake, Ti axleback
                    http://www.fquick.com/slow-v6
                      I've seen pics of both bays, from up top & from below. No, the tabs won't bend. I took this puppy
                      in and out a couple times using the tabs. Yeah having no cowl overhang is a curse I must bare ;) ,
                      94 comero 3.4
                        i took out the engine out of the top a week ago and that was with the upper intake off, i had no clearance issues by doing this i will post pics soon
                          Good stuff. You drop it in yet? Let us know how that goes.
                          94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
