I have a 97 rs vert. It seems that my rear defroster isn't working anymore. The light lights up on the button, but the moisture on the window in the cold mornings don't go away til the whole inside heats up. Any suggestions. The 2 tabs are both hooked up on the window. Anyway of testing them to see if they're working or not.
Rear Defrost not working
1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>Tags: None
Sometimes tint hampers their effectiveness. I have tint on my back glass and only like 1/2 of the defroster things work. They all worked fine before.1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
I have this happening on my sunfire(96) right now...(daily driver).
We tested the switch and the connectors at the back... ground everything! Everything seems to work, except there's no heat. It gets 12vdc power back there and there's continuity between the two connectors... but no heat :(
If you figure this out, please post it! :D1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
run the multimeter on each line of teh defrost elements. Some may have continuity, others may not. For those that don't, find the break in circuit, & get repair kit to fix. Autoparts store or JC whitney has it.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
