Oil pressure survey - FirebirdV6.com/CamaroV6.com Message Board
Oil pressure survey
  • Oil pressure survey
    Ok folks, I've probably one of the few that have gotten the experience of moving from mild weather (Washington State) to warmer weather (Southern California) with my vehicle.
    In washington the oil pressure was nailed at 60 from summer to winter. Down here it's at 60 when cold, but drops to 40 after running a while. (WTF?)
    Can you guys let me know:
    1) Engine size
    2) Climate
    3) Oil pressure at cold (idle)
    4) Oil pressure at hot (idle)
    5) Type of driving
    6) For shins and giggles - Voltage reading
    <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
    Oil press-
    62-68 psi right after startup, regardless of outside condidtions.
    right on 60 at operating temp.
    voltage- usualy 14 volts, but sometimes when I push in the clutch and let the rpms drop, the voltage drops to 12 for a few seconds.
    [ October 01, 2003: Message edited by: malice10985 ]</p>
    1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
      volts? 14ish
      i dont remember the idle? probably around 55ish? Running its probably around 65ish.
      i couldnt tell you the difference between hot and cold.
      Type of driving? "slightly spirited"
      Visit My F-Body Page
        The manual says oil pressure can drop to 20 psi when the engine is hot and still be considered normal.
        <a href=\"http://f1.pg.photos.yahoo.com/ph/slappy3243/lst?&.dir=/New+Firehawk&.src=ph&.view=t&.begin=1&.order=&.don e=http%3a//f1.pg.photos.yahoo.com/ph/slappy3243/lst%3f%26.dir=/New%2bFirehawk%26.src=ph%26.view=t/\" target=\"_blank\">2001 10th anniversary Firehawk,</a> Bilstein suspension, Auburn rear, M6<p>For sale: 2000 Pontiac Firebird, black, A4
          when I'm idling alot in ****ign dallas traffic it will drop alot sometimes, but never below 20
          I'll have to make note next time I drive but mines like malice
          \'01 Trans Am WS6 5.7L M6<br />Stock now w/ K&N and whisper lid<br />Coming soon: B&B Triflow catback, MAF, 85mm throttlebody, headers, supercharger?
            In the 100+ weather is drops to 40-45 or so.
            1997 Dodge Viper GTS
              Hangs around 75 psi(plus or minus 10 psi) regardless of outside temp and/or engine temp or rpm.
              2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
                65PSI reguardless of outside conditions
                Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
                  Drops as it gets hotter while idleing.
                    cold, mine can peak at 85. after running awhile, it mellows out to around 65 and warm/hot will settle in at idle at about 50-55 psi depending upon the load on the engine (AC,extreme temp, terrain, etc.) I get a little guage shimmy if she needs an oil change (viscosity breakdown I guess?) But other than that never below 50
                    \"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
                      1) Engine size
                      2) Climate
                      5) Type of driving
                      1- 3.4L
                      2- 66 today.. usually 70-80
                      3- little above 40
                      4- about 20
                      5- gentle usually
                      6- about 14 without my headlights on.
                      I asked this before about other 3.4Ls and mine was like the lowest oil pressure out of everybody..
                      <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
                        Moved from NE (and drove in winter) to Florida, runs about 65in both climates, I dont remember seeing it below 60. As for driving, half throttle hole shots and lots of passing (too many idiot cell phone heads). Voltage ~14.
                        01 Camaro A4 Convertible
                          1) Engine size 3.8
                          2) Climate winter 15-33 summer 75-98 or so
                          3) Oil pressure at cold (idle)80psi
                          4) Oil pressure at hot (idle)70psi
                          5) Type of driving .heavy: [img]graemlins/rock.gif[/img]
                          6) For shins and giggles - Voltage reading 14
                          But the downside of high pressure. Rear main and oilpan leak.
                          Black 2000 Y87 Camaro with T-tops ,SLP bowtie grill, Suncoast Creations Ram air hood and air box,Hypertech pp3,magnaflow cat back,and hi flow cat. <a href=\"http://members.cardomain.com/sorn09\" target=\"_blank\">http://members.cardomain.com/sorn09</a>
                            1) 3.8
                            2) Mild winters, hot summers
                            3) 65
                            4) 45
                            5) Mostly in town -- but how I drive doesn't seem to change the oil pressure at idle.
                            6) 14V when cold, as low as 13V in hot weather.
                            I use 10W-30 Mobil oil (not synthetic) and AC PF-52 filter.
                            At anything over 1000 RPM oil pressure stays at about 65 on gage, hot or cold.
                            2002 Camaro Coupe<br />Navy Blue, A4, Y87<br />Whisper Lid, Raised Air Box<br />SLP Bow-Tie Grill, HPP3
                              y not synthetic?
