How often is this suppose to be changed? As far as I know it has never been changed.Should I do it or is it not meant to be changed?
Power Steering fluid change
You don't really need to change it unless you change the pump or it smells/looks burned.
If you want to change it when you change your tranny oil, then do it. It's just a ***** to change because you have to bleed the system.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
just top the fluid off it it starts to make noise/ hard to turn wheel1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
What if i just pull the tube and drain it? can i fill it up after that? what do you have to bleed?
it has to be as easy as i think...Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
hey fellas i seek your knowledge...Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
Yep, you could drain it that way. Just be very sure not to get any dirt in there. When you have refilled it do the following:
Jack up the front wheels of the car
Remove the cap on the PS Fluid tank
Turn the wheels stop to stop around 10 times
Check level in PS Fluid tank
Run the wheels stop to stop for another cycle of 10
Check/top off fluid once more
You are good to go!1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
A great additive is made by "Lubegard" their power steering additive converts GM spec fluid to the more stringent Honda type fluid.Lubegard is known the world over for excellant additives that GM for one use & endorse.I changed my fluid for good measure & bought Lubegard P/S at Napa,Pep boys also have it...geocor
