Ok, so i am looking into buying a 98 Firebird with the 3.8...around the 100,000 mile range due to a lack of money. Are there any specific things that i should look out for when i am buying this car? I am talking about trouble spots that are common, that i might find when i test drive the car. Anyone have some pointers...?
What to watch out for...?
yeah, look out for cars with around 100K on them ;)
umm.....
somethings could be like a leaking rear main and rear pinion seal. check the fluids like the oil for metal shavings...just incase. just check around the engine area for leaks or previous leaks. the cat might be ready to be changed soon if it has not been changed. your O2s should be coming around to there second changing. check the antifreeze to make sure the coolant isnt getting sludgy.
those are just somethings off the top of my head...
Also, chekc the power window motors. See what condition th oil is in, and smell it. Check out the pop-up headlights. If T-tops, check for good seals. Check tire condition. And just give the engine a good look over, and listen real carefully to it. Good luck. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
What all is included in a FULL TUNE UP ?Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
02 sensors, thermostat, PCV valve, plugs, wires, maybe air filter, oil change, manual or automatic fluid change, collant system flush, rear end gear oil change and new gasket. Stuff like that. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
just remember that parts needing replaced can quickly exceed a slightly higher car payment!! ;)
tires, brakes, shocks,02 sensors, cat, exhaust, and rear ends dont last forever on our cars.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
Originally posted by j_downey50:
why not get an older 3.8 bird (96-97) with less miles?
When i get the car i am already planning on making all the major upgrades and tuneups such as exhaust, intake, tires, and some drivetrain stuff, so im not too concerned about that. Obviously the car is going to need smaller things tuned up like oil changes and the other thigns that you guys mentioned, so that will be my first priority. Thanks for the info, and ill probably have my bird in early january...Current:1962 Pontiac Tempest 4 cyl.<br />Future:1998 Pontiac Firebird v6
yup...everything here...full tune up...no leaks...look close because they can wipe up a leak in the engine compartment and you can see the smears...also look for differences in the paint between parts...that will let you know if its been in an accident and needed to be repainted...the CARFAX reports are pretty good too ...look at the underbody..if its been sitting a long time or something it could be pretty rusted and then you'll be looking at all new breaks, fuel lines, etc...good luck!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Just make sure [as it sounds like you're doing] that you have a little money left over to do an unexpected repair or two. Carfax is a good idea. It's hard to find one of these that hasn't had like 6-7 previous owners and a serious accident.
Most of these cars are driven pretty hard, so I would be concerned about the remaining lifespan of the automatic transmission at 100K. An OEM clutch at that mileage would probably be done by then also, unless you got a really considerate former owner. Other than looking for leaks, yanking out the plugs would tell you if the car is using oil. Many of these cars have leaky differentials [mine doesn't]. The OEM shocks would also be done by that time [according to some of the suspension gurus here].
The only other advice I would give is to look at the little things-- tires/brakes/rotors, body damage, broken switchgear. If the previous owner didn't care enough about the little things, you can be sure he didn't give a damn about the larger problems as well.
I personally also stayed away from any modded car, since I think that's a good sign that the owner probably beat the sh!t out of it. [no offense to the rest of you here]...\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
