Oil Change Light???? - FirebirdV6.com/CamaroV6.com Message Board
  • Oil Change Light????
    Earlier this week a light on my gauge panel went off that said "OIL CHANGE" which is probably scheduled maintenance type stuff but i got an oil change maybe 3 days before it came on. How do i reset this light? Thanks in advance for any help!
    2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
    I'm not sure about the camaro, but on the 2000 Monte Carlo SS I worked on, to clear out the oil change light code we turned the ignition on and pressed the gas pedal to the floor 3 times. Using the scanner to remove it didn't work.
    May sound absurd, but shouldn't hurt to try.
      press and hold your trip button on the odometer with the ignition on, the oil change light will blink when it's done
      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
        what little g said
        2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
          Owner's Manual???
          Try page 6-17 of your owner's manual. I just downloaded the manual for an 01 Camaro, and it's right there. ;)
          Matt
          1998 Mystic Teal Camaro M5
