Tension Pully - FirebirdV6.com/CamaroV6.com Message Board
Tension Pully
  • Tension Pully
    The bearing in my tension pully is going bad, and is making an annoying sqeaking noise. Can somone please tell me the part number for just the pully it self, i dont need the whole assembly, or am i going to have to buy the whole setup. Also if i buy the new pully will it come with a new bearing? I searched this forum and the only part number i came up with is 24506755, but this seems to be for the idler pully. I have a 97 3.8 Firebird. Im looking to buy the pully from http://www.buy-oem-parts.com/storefront.htm
    if you just need the pully you can just replace that. You can get them anywhere. Gates sells them. If it's the tentioner arm itslef you need to get that from the dealer..
    1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
      Thanks HBH, yeah i just need the pully not the arm. I tried autozone & Napa but they seem to never have anything for my car. Does Gates have a website?
        gates numbers
        Idler Pulley Belt Drive Pulley 38006
        Tensioner Pulley Belt Drive Pulley 38015
        Tensioner Assy.Belt Drive Tensioner 38152
        The one in bold is what I would "assume" you need although the 38006 part is more like teh standered pully... If you give these part numbers to autozone or advance they can interchange them to any of there part numbers and then show you what it is and you can pick out the right one
