Hi i got a hypertech 160 thermo from autozone. My father was saying i should have got a gasket with it. Is he right? this is for a 3.4.
160 thermo
You can reuse the one off the one you're replacing.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
better just spend a few bucks and get a new one and scrap the old one off. Your old one has been in there for a long time. They have them right at autozone for it.
Originally posted by V8 Killer:
You like in NJ?
Is it really necassary to have a 160?2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
and if he doesn't drive it in the winter then there is no worries about the heat not getting really hot
The heat will not be affected. We're talking 160 degrees, thats plenty hot enough to run the heat and you won't notice the difference. I've had my 160 since fall and it's fine.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
Originally posted by Little G:
The heat will not be affected. We're talking 160 degrees, thats plenty hot enough to run the heat and you won't notice the difference. I've had my 160 since fall and it's fine.97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
