tranny fluid - FirebirdV6.com/CamaroV6.com Message Board
tranny fluid
  • #16
    There's a way to flush the tranny yourself, it's just time consuming and expensive.
    It all depends on how much ATF you're willing to buy.
    1) drain your tranny pan. Having a trans pan plug is invaluable for this.
    2) refill the tranny pan.
    3) run the engine until the fluid is warm.
    4) drain, refil.
    5) run engine again for a few minutes, shifting from park to reverse, to drive and back.
    6) drain pan
    7) repeat steps until you've put about 20-30 quarts through the transmission.
    Good luck finding a place to dispose of 20-30 quarts of atf for you, though. Even better luck finding a way to store all of it until you can dispose of it too.. a couple of gallon milk jugs will be good to have around for this.
    2001 Camaro, 3.8 v6. Five speed. Red. SLP Torque arm, SLP CAI, adj. panhard bar, lcas, eibach springs, 3.73 gears and Zexel-Torsen T-2 LSD.
    • #17
      Originally posted by therock:
      get some trick shift from b;m
      yeah it adds another 10hp :rolleyes:
      • 187shark
        by 187shark
