Whenever my car is idling it makes a whining sound from the engine bay. It gets louder the more I accelerate but dissapears at about 50 mph. I know it is not supposed to be as loud as it is because i'm by other 3.8's all the time and they dont have that sound. Its becoming really annoying, Its even louder than my flowmaster 80 series. Any ideas on what it could be or what I should do? Thanks ahead of time for the help.
Engine whining sound
Alternator, belt tensioner, waterpump, even the belt itself can make noise like that, but I'm with camaroincal on my vote: probably the alternator, given your description.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
If not alternator, then listen up. I recently had an idler pulley go out on me. They have a small bearing inside and on mine, it somehow stripped itself out. You can get a replacement at most any auto parts store. *Be Sure* when you take it off to loosen the opposite way of what you would think....they are reverse bolted on.1997 30th Ann. Camaro RS <br /><br />Aluminum CAI, Magnaflow Cat-Back, Magnaflow Hi-Flow Cat., 160 Thermo. <br />B&M Shift Plus, Taylor 8mm Spiro Pro Wires, NGK Iridium Plugs
more than likely your alternator belt my brothers just went on this stratus sounds like the same thing.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
In the last 2 years I have had to replace the alternator, the waterpump, and the tensioner pully on mine all of these things made this sound.Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
I just recently replaced my alternator, it was making a whining sound. I replaced the tensioner, but that didnt help. A little bit of advice, replace it now, b/c if you dont, all of a sudden you'll be driving, and your windows wont work, your lights will dim, and eventually your car will die.
PS. If you do it yourself, once you get the belt off, start it up for a second, it will bada$$!!Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
Could be a number of things. I have a whining sound coming from mine too, first I thought it was my belt tensioner AGAIN. But it's coming from AC compressor area, that little AC clutch or whatever at the front of the AC compressor. Mine is pretty loud, my friend thought it had a supercharger the first time he heard it. LOL<a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
