Or if you need a wake up in the morning, just start the car and before it gets hot run your hands down each wire to check for dammage. You'll know which ones are broken when you go for a small flight. [img]tongue.gif[/img]
SES...P0306....CHANGED PLUG AND CAR STILL STUDDERS
Thanks for the info tWiStEdBird, at school right now as soon i change my wire ill get back to you if any problem presist.97 Camaro 3.8(of course)<br />MoDs:K&N Filter, Flowmaster(muffler only)<br />SLP CAI<br />Z06 Motorsport Rims(Ventus 255-40/R17)
Hello,
I had this problem with my car twice-- both times it was caused by a failing coil pack. One time it got worse slowly over a few days and once it got worse really quickly. Symptoms were similar to yours.
There are three coil packs on top of the engine; they're where the plug wires terminate. Although they're some really weird sized nut, you can improvise removal with a standard sized one if you're gentle. Just remove the 2 nuts, pull up to remove, replace the little rubber gasket, and reinstall. MAKE SURE you reattach the plug wires to the correct terminals on the coil!!.
A regular, one-year warranty coil from an auto parts store will run you about $20 each. Even if it's not the problem, it makes sense to keep a spare in the car-- trust me...
I think you're going about this in the right order: plugs/wires/coils/module that the coils plug into.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
YES...I got some wires needed only though i needed 1, and it worked, IT WORKED...I my car has been driving like crap for like 3 months(being REALLY busy/lazy) and if feels Wonderful knowing that i can push my car with out a problem, thank you for the advice on the wires. THANK YOU!!!!97 Camaro 3.8(of course)<br />MoDs:K&N Filter, Flowmaster(muffler only)<br />SLP CAI<br />Z06 Motorsport Rims(Ventus 255-40/R17)
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...1 day ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...1 day ago
I stopped driving...3 days ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...1 week ago
by KubesI notice a lot of headlight assemblies on amazon for 1998-2002 but zero for 1997. Am I to assume it’s not possible to upgrade from my 4 rusted out light...1 week ago
