ZZPerformance SUCKS - FirebirdV6.com/CamaroV6.com Message Board
ZZPerformance SUCKS
  • ZZPerformance SUCKS
    I just wanted to let everyone know how bad this place is. I ordered a custom PCM from them and they never sent it! Everytime I call to see what was going on I got a different excuse - everything from they are having trouble programming it to they didn't have my correct address and the PCM was returned to them. It's been a MONTH now and I still didn't get anything from them and now they don't even return my calls. I cancelled my credit card charge and put in a dispute and got my money back. **** them. Worst company EVER.
    All this being said, who else can do custom programming on a 1999 v6 Camaro? Any other companies that know what they're doing?
    Just curious what you need custom programming for?
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
      I have 3.73 ratio rear end gears and have a done-up exhaust w/headers, etc... I just wanted them to fix the speedometer and also calibrate it for 17" rims for later and also change the timing, etc .. It should be the simplest thing to do for them.
        If I remember correctly, ZZP contracts out the work for reprogramming PCMs. Also I think they're the only ones that reprogram our PCMs.
          But they don't!! The guy was like there is no program to re-do a '99 pcm and they have to do it manually. The contractor they use is some guy Dave who does this on the side. It's not like they contract out to a real company. Just some random guy.
            http://www.camarov6.com/cgi-bin/ulti...&f=16&t=001712
            Matt
            1998 Mystic Teal Camaro M5
              So what are the alternatives? Will GM be able to do this? Can they at least replace a PCM to a different year so a Hypertech could work? There has to be SOMETHING people can't drive around with their speedos not working it's kind of illegal not to mention a little stupid.
                GM never intended for you to you to make changes to your car. If you decide to change gears or something, that's not their problem. Why should they have to do anything to help? If it's that illegal and stupid, why do it in the first place? That being said, I hope you can find a way to fix it.
                Matt
                  But people modify their cars all the time. And there are companies that do this stuff you can get a repgram done for a z28 anywhere. Hell you can reprogram a v6 too but why not the '99 model specifically? Is there like some conspiracy against them? [img]smile.gif[/img]
                    <blockquote>quote:</font><hr>Originally posted by 98Camaro3.8:
                    GM never intended for you to you to make changes to your car. If you decide to change gears or something, that's not their problem. Why should they have to do anything to help? If it's that illegal and stupid, why do it in the first place? That being said, I hope you can find a way to fix it.<hr></blockquote>
                    why is it illegal and stupid?
                    your post makes 0 sense to me.
                    i see GM not doing the mods, but it is no where near "illegal" and stupid is in the eye of the beholder.
                      <blockquote>quote:</font><hr>Originally posted by gregmondro:
                      <hr></blockquote>
                      He said it was illegal and stupid to drive around like that.
                      Matt
                        <blockquote>quote:</font><hr>Originally posted by Dekay:
                        I have 3.73 ratio rear end gears and have a done-up exhaust w/headers, etc... I just wanted them to fix the speedometer and also calibrate it for 17" rims for later and also change the timing, etc .. It should be the simplest thing to do for them.<hr></blockquote>
                        Hypertech makes a HPP3 that will recalibrate your speedo for gear and tire changes for the 99-02 v6 f-body
                        I can\'t drive 55<p><a href=\"http://www.geocities.com/kotenberger/camaro.html\" target=\"_blank\">My Camaro</a>
                          ive done buisness with zzp and they are a good company
                          i also know in the last month they have been veerrry busy with other stuff (getting there car ready for IDD4 where it set a record for the m90 supercharger, after swaping in a new engin 2 days before)
                          besides them having other **** to do THEY DO NOT DO THE PROGRAMING
                          A guy by the name of dave buckshaw (if i remeber right) does it and honestly i doubt he has ever done a 99 camaro/firebird pcm so im sure he was probably working on it
                          you should have called before
                          Think about it who on here has a car running with a reprogramed pcm that works the way its supposed to ummm none
                          did you even try asking for your money back i bet not you just put a claim in
                          cry me a river
                            <blockquote>quote:</font><hr>Originally posted by 98goldv6:
                            <hr></blockquote>
                            Hypertech only works on 00-02 models. NOT 99....
                            Eric
                            2005 Mustang 4.0
                            1996 Camaro Conv
                            2000 Ford Excursion
                            "Darkness Falls"
                              <blockquote>quote:</font><hr>Originally posted by merlinsrealm:
                              <hr></blockquote>
                              upon furter evaluation, you are correct :D
