power-steering fluid/brake fluid interchangable?(i cant read) - FirebirdV6.com/CamaroV6.com Message Board
  • power-steering fluid/brake fluid interchangable?(i cant read)
    I was checking everything on my 93dakota and camaro today and times like this is why ive got two vehicles.
    My powersteering in my camaro was about four inches low!(put a v8 rack in, lines arnt tight) So i grab a bottle of powersteering fluid and fill it up and then notice i just put half a quart of BRAKE FLUID in my pump. I used to use tranny fluid in my 77 newport's pump, is brake fluid ok in or should i drain the dang thing? I dont suppose they make a brake fluid additive to change it into p/s fluid. If anyone is a brake fluid expert and has a sec it would be appreciated.
    Erik
    94 Camaro A4 Dark-Maroon 153k<br />Slp CAI,Transgo stage2,Tranny Cooler,AL ds,bilstien, eibachi\'s,bmr stuffs.
    NO NO NO NO.. get it out NOW. if you ran it throug all ready then be prepered to replace your power steering system.
    1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
      Thanks, I didnt run it through though i was pretty tempted. It's going to have to sit in there for half a day before i get a sec to drain it.
        I would take a turkey baster or similer and suck it outa there and then flush it well.
        • Manimal
          Coil springs
          by Manimal
          6 days ago
        • Manimal
          Newby here
          by Manimal
