synthetic is in - FirebirdV6.com/CamaroV6.com Message Board
synthetic is in
  • synthetic is in
    got 85k on the car, and just switched to mobil 1 oil and filter today, drove it around put 10-20 miles on it and i dont see anything leaking. something i didnt expect was now when i gas it, it sounds alot meaner and deeper. [img]graemlins/banana.gif[/img]
    should i take it easy for a while or should i do the opposite. also, how long should i wait to change again, would 5k be too soon?
    Although you're probably tired of my advice by now--
    Drive it the way you always do; keep an eye on the oil level at each fill-up [looking for leakage]. If you're easy on the car, I wouldn't bat an eyelash at keeping it in for 7,500 miles, because you certainly have the oil and the filter to do it. I change mine every 5,000 because occasionally I drive it REALLY hard [drag strip] and I use a slightly cheaper AC filter.
    In normal driving [not like 80% city or WOT all the time], I would keep it in 7,500 miles or when the "oil change" light tells you to change it, whichever comes first. You know how to reset the oil change indicator, right?
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      I had 130K on my old 3.4L when I switched to synthetic and drove it hard w/ no leaks. You should be ok. and w/ synthetic I changed it every 5000 miles. some may say that's too soon, but I think it's better to do it sooner than let it run longer ;)
      \'97 Camaro 3.8L
        I just use Castrol GTX.
          I put synthetic in mine at about 80k, and now she pisses it out the valve cover :(
          94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
            how do you reset the change oil light
            OLD: 1999 3.8L V6 Firebird<br />NEW: 2003 Chevy Silverado
              If it's the same as my 2000, with the key in the run position, hold the trip meter button for 10-12 seconds until the "change oil" light blinks a couple of times.
                It sounds meaner now, LOL.
                  LOL,your mind is playing tricks on you dude.
                    mobil-1 is top qaulity. nice work.
                      Most of the time (after I have been useing if for several oil changes) at 3000 miles the oil isn't even deep black.
                      It will get dirty fast becasue you just started useing it.
                        Originally posted by V8 Killer:
                        </font><blockquote>quote:</font><hr />Originally posted by 00firebird:
                        LOL,your mind is playing tricks on you dude. </font>[/QUOTE]lol im not kidding though, just a little when i give it a WOT.. this is my first change since i bought the car 2 months ago, and the filter looked so old i had to stab it and turn it with a screwdriver. but seriously, it used to get a really high whining pitch before i changed it, now its not there.
                          my question is, what should the oil pressure be at? mines been around 70-75 while driving and 65 at stoplights. its higher than it was before i changed. i thought synthetic was supposed to make it lower, could something be wrong?
                            Whoever told you synthetic will make the pressure reading lower is full of it.
                            Your pressure readings sound about right to me. On my gauge, it will touch 60psi with the engine idling and hot. It will reach about 80psi with the engine not idling and cold.
                            Not that our oil pressure gauges are really accurate, but having slightly higher pressure readings after an oil change is a typical thing, as old oil sometimes loses its viscosity ["shearing down"].
                              I use synthetic and I just change the oil when the oil change light comes on (same thing when I didn't use synthetic). GM swears by that thing so that is good enough for me.
                              SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
