I need to replace my fuel filter on my 94 Camaro with 3.4L V6, where is it located? Also, what do you recommend for replacement spark plugs and wires? What else should I replace and do since I have 167,000 miles? Thanx.
You are sitting on it! Well, almost. It is located under the drivers side of the car, infront of the rear wheel well a bit. It is a metal cylinder with fuel lines on both ends. Shouldn't be hard to find.
yup... between your driver well and driver's side rear tire you'll see it tucked up in there. have a catch pan ready for the fuel that comes out with it... I can never seem to change mine w/o getting gas all over my hands :(
1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
3 days ago
